Hi, just want to know for my 1989 W124 E230, does the brake lights are only active when the car is started & running? My newer car Myvi does not have to start the car to activate the brake lights, meaning lights are active when car is not started & when brake is depressed.Are all w124 same model as mine need to start the car, then the brake lights are only active when brake is stepped on? is this normal for my w124? Thanks.
W124 Moderator
Normal.
Welcome to the forum Spider. It will be very helpful for you if you'd spend a few minutes and complete your profile. Also, read through our DIY sticky and you'll find the normal issues encountered with these cars.
Welcome
Jayare
Sent from my XT1710-02 using Tapatalk
Normal.
Welcome
Jayare
ok..done..thanks ya
