1999 C43
Need help, my 1999 c43 brake light is staying on, I just had new pads installed and fluid level is OK but light wont go out, also my instrument cluster lights are not working and gauges not working either. Everything was working about 1 month ago and I started car again last week and now lights and gauges are not working. What do I do now?
Tercel
did you change the brake sensors? If no, that could be your answer.
83 500SEC, 84 300TD, 86 190E 5.0 M113, 87 300D, 01 CLK55, 02 C32, 02 C320T, 03 C320T4, 03 E55
Check fuses first. When you say brake do you mean brake lights in the rear of the car or the pad warning light in the cluster?
1999 C43
brake light
Thanks for the help, brake light on the cluster was burning when engine was running. Changed the sensors (didn't help) checked fuses (finally!!) all is good on cluster now.
