Mercedes 300D
My reservoir has had a slow leak from the rubber grommets between the reservoir and master cylinder for a while now. Due to lack of funds, I haven't had my shop make the repair...and, they were all too excited to charge $$$ for the job. I'm now able to at least tackle the job, but do I need to replace the master cylinder? Or, would I just need to replace the rubber grommets? Suggestions are much appreciated.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Just replace the grommets and see if that stops it- it likely will. Couple of bucks and pretty easy.
Len
Mercedes 300D
Thanks! That's kinda what I thought. At least it would be the best first step, I guess. I just hate when shops are too eager to tell you that you need all this work done when you may not.
