DOT 4+ is not covered in FMVSS spec 116 ( the "DOT spec") but has been used as a reference by most European car manufacturers since the mid 90's.
MB spec 331.0 for DOT 4+ brake fluid has a Dry boiling point of min 260 c and a wet boiling point of min 180 C. That's the same as FMVSS DOT 5 (including 5.1 for the poly glycol version).
Viscosity specified is max 1500 mm2/s @-40c .That's same as DOT 3 , lower than DOT 4 at 1800 , but not as low as DOT 5 at 900.
Manufacturers of the fluid such as Pentosin, ATE, Aral ,Mobil ( in Europe) are shown to meet MB 331.0 as well as the comparable specs of Audi, BMW, VW , Porsche, Land Rover, Volvo.
Flush intervals for MB and Volvo, which I have ,are 2 years ; seems to also be same /similar for others.
I consider that the manufacturers designed the hydraulic system, including the choice of fluid ,to ensure proper operation over a wide range of conditions.
Since the specified fluid is available I see no reason to second guess them to save a $.
