1 - 9 of 9 Posts
1990 500SL
I recently changed rotors/pads and took the front callipers off to get it painted so i let the brake fluid drain out figuring it would be better off to put new fluid in afterwards
I see now that it was not a good idea because brakes are not working unless i slam my foot down
Im guessing the fluid needs to recirculate some how
· R129 HTT Founder Member
040 96' SL500, 368 08' E550 4Matic, 9147 13' Sprinter 2500
There usually is a relief valve, I have never done it on an SL but usually you have someone pump the brakes while you release air in the lines through the relief valve/s. I suggest you do a search of this forum to see if it has already been discussed.
1989 560sec 6.0L AMG & Renntech, Various W140's (V8 and V12's), 1984 500se Euro,.......
SL500, CL55, E350, E320
Does anyone has a part number for brake fluid for 1999 SL500? Does all DOT4 work? The price difference is minimal (I think) so I would like to use the OEM fluid unless you think the aftermarket is the same. What is the best place to buy? Thank you!
Thanks.
I have found these OEM part numbers for brake fluid. Hope it helps someone else
MB PART # 000 989 08 07 01 (1L)
OR # 000 989 08 07 11 (5L)
000 989 08 07 10 (1L) is a can version of the 000 989 08 07 01 (1L) plastic bottle above.
1 - 9 of 9 Posts
