2005 C240
The PO broke the nipple off the brake booster line and had it epoxied back on. I was checking it for leaks the other day and it just snapped off. I think the PN is 2014302629
If that is the correct PN they are $90. Are the 190DT different than all the rest of them thus costing more? Is there a good alternate solution?
Thanks,
Chris
81 500SEL, 84 300TDT, 86 + 87 190E 2.3, 91 + 92 300D 2.5T, 95 E320 Wagon, 09 C300 4MATIC
190DT is a turbo-diesel 190 so it's probably different. Make sure you buy from a good brand, the only brand I saw on one website was Uro and they're terrible. I'd buy OEM if you can, or just use some heater hose to fix it if you can...
1987 190D Turbo
When mine broke, I bought a barbed hose coupling and epoxied one side to to the fixture. These usually have a flange in the middle that's a perfect surface for adhesives. Worked well for years. If this link works, you can see what I'm talking about:
http://www.mcmaster.com/#91355k88/=p85hhi
Don't bother going to Mercedes. They do have the part, but the stock is in Germany. It will take two weeks and cost three times as much.
2005 C240
Discussion Starter · #5 ·
McMaster-Carr
Thanks for the info. I will probably be trying this before anything else!
heres one for $37 with free shipping Mercedes W201 190E 2 3 Brake Booster Line Trucktec Brand New Ships Fast | eBay
EDIT: im half asleep still you have a 190d not e, might work still though ??
Not sure about interchangeability.
