Hi,
simple tasks can sometimes become very frustrating.
Don't like using the brake pedal to bleed as in the master brake cylinder the piston is pushed into an area it normally does not travel into. If you had good pedal pressure before you started the repair doubt the master cylinder is leaking. I am pressure bleeding my brakes and have had good success with it. Also can do it without the help of another person. There are commercial units available or you build one yourself out of a small garden sprayer. I am using a very simply system made by Gunson by the name of Eazy Bleed. Check with www.mossmotors.com in Goleta, CA. Have also another unit which is used with a bigger air compressor but in my case does not work as well. Use Google to find details about the selfmade pressure bleeder. hope, this helps
