1 - 11 of 11 Posts
'01-E320 & 02-ST2
Hi, Folks.
Came across this on the net and thought it might be of general interest, but particularly to the more tech-minded folks here. I also saw some posts regarding simply blowing on it to watch the voltage fluctuations, see if they are in range, etc. (Of course, you'll need to clean it after blowing on it....:D)
At any rate it provides information that is useful to help diagnose the MAF itself, so that's an option if you're getting codes and want to dig in a bit before buying a new MAF.
Take care and enjoy the ride,
Greg
Thanks for sharing this Greg! :)
'01-E320 & 02-ST2
Discussion Starter · #6 ·
Thanks to WitekM for posting the attached related to diagnosing the P0100 code on a MAF ... dovetails well with the other one from Bosch.
Greg
'01-E320 & 02-ST2
Discussion Starter · #7 ·
Time for a bump...here you go, Lou ... and particularly, Ron.
03 E320 4M Wagon & 97 E320
Thanks, Greg.
I read through both PDF and also compared to my WIS docs. I am adding the third doc to make this more compete.
The Bosch doc mentioned the test of the air temp sensor because it is part of the MAF. The P0100 Mercedes doc did not mentioned that. However, the P0110 doc mentioned the air temp sensor test by measuring both voltage and resistance as a function of air temperature. Here is that part of the test.
1999 E320 Wagon (306,000 + miles)
Thank you, sir! I saved all the attachments and will read through them. Good thing I didn't throw away my original MAF, I can even make comparisons.
Looking for MAF/AMM Running Specs
Hi? I am new here. I am looking for MAF/AMM running specs. on part#
MB#0000 940548 Bosh# 0280217100
94-96 C-class Maf
Please help if you can. Thanks
1998 E320 Wagon
Just a quick question. The Bosch posting lists two different types of MAFs (HFM 5 and HFM 2). Each has several part nos. and the electrical characteristics are different for each part no. The second posting (WIS) has some data but no reference to which type/part no. it applies. Perhaps the ranges given provide enough leeway for qualitative testing. Maybe the year/model/engine designation for the second posting could be provided?
Thanks, Greg for the information.
1 - 11 of 11 Posts
