1 - 9 of 9 Posts
SLK350
The other night I thought that I ought to check my oil level after reading someone's horror story about his engine burning oil and having his engine replaced. (How's that going?) My car's oil level was fine, by the way.
In the process I learnt something useful - after the struts have pushed the bonnet up to their max, you can push it further by hand until it is almost vertical. The hinge / links stop it in that position quite safety.
It was easier to see what I was doing and move around with it that far open.
cheers
roadsta
SLK350 6MT
I found the same thing about the hood. But, it really did not help reading the oil level because of the POS dipstick. It is absolutely the worst I have ever encountered!!!
SLK350
rickboy - 5/15/2005 2:06 PM
Have to agree, it is poor. It helps a lot if you use a piece of clean white tissue paper. After you have taken the reading, press the oily end of the stick against the white paper, without moving the paper. That way you can clearly see the brownish oil on the paper, and where the oil level is on the dipstick.
roadsta
SLK350 (apr 15)
roadsta - 5/13/2005 12:06 AM
Neat idea, I'll try that! Maybe a paper towel ...
SLK 55 AMG
I think you need to push the bonnet up all the way if you wanna bend the wipers back in order to clean them...
The SLK books also have diagrams showing that yes, you can open the hood up even more then the first notch (just check out the drawings from the side view shots on mbslk.de )
SL550
Warning - Garage door hazard
Keep in mind that if the hood is in its full open position, it could be in the path of your garage door. Especially the hardware connecting the electric garage door opener to the door.
SLK350
RE: Warning - Garage door hazard
fgwinn - 5/16/2005 10:47 PM
Good point! Thanks
roadsta
1 - 9 of 9 Posts
