w163 ml
Any you helpful people know how to remove the bonnet badge because i have bought a new one because my other one faded
thanks
2011 GLK,2007 S550,2003 S55,2008 CLK,2009 C300,1996 E300,2005 E320,2002 E3
I used a single edged razor. Be careful not to depress into the paint. After removing it, I used some Goo Gone or Goof off to remove the adhesive backing. I then wiped the surface clean with alcohol, and reinstalled the new badge.
2020 MB GLE 450 4MATIC, 2015 BMW M4
woz - 4/30/2005 4:44 AM
thanks
I'd stay away from the razor--to easy to damage the paint. Use a heat gun (hair dryer if you don't have one) and dental floss or thin fishing line and saw back and forth, then remove residue.
If you are talking about the "MLxxx" badge, it is attached with adhesive. Use a blow dryer to soften the glue, then dental floss to remove the individual numbers and letters, then a bug & tar remover to remove the remaining adhesive.
If you are talking about the three-pointed star, it is NOT glued on. It has three pins on the backside (near the center of the arms of the star) that are pressed into plastic fittings on the body. To remove it, slide something thin, such as a business card, behind the star until you get enough space to grip it (the best place is in the center) with your fingernails. It just pulls straight out.
- RODNEY
98ML320
I think he's talking about the round Mercedes emblem on the center front top of the hood rather than the grill star.
Couldn't tell you how to remove that but I don't think it's glued on. Usually those things are just mounted on (bayonet style) or at least that's what it looks like when you look at the hole left after someone has stolen one. The thieves seem to use a screw driver to pry it off.
Good luck
Yes, Bigcvatny, I believe you are correct! I failed in my English-to-English translation! Bonnet=hood, boot=trunk.
- RODNEY
