1989 300 TE
Has the MB bolt pattern changed since 89 and do they very in class? Just wondering what wheels are interchangeable with my 89 300TE
SL320, 300e, 450SL
Go to tire rack and do your own cross reference
showing what offsets/sizes fit which years/models.
good luck.
1994 E320
Rob,
The standard Benz bolt pattern is 112/5, and this hasn't changed in at least four decades, so don't worry about that. Instead, you should worry about wheel offset and width.
As a starting point, any 7" wheel with an offset greater than 44 (the original standard offset for the 124) may not fit
(the rim may fit physically, but the tire mounted on it will rub the front shock if it were wider than 195.)
As a rule of thumb, if you plan fit a wheel that's wider than 7", you should make sure it has LESS offset by at least half the amount of the added width.
Example: If you wanna fit an 8" wide rim, the offset should not be more than 30mm (ET30), but ET35 will do if the wheel was 16".
Hope this helps,
Shady
Certain models do have a different bolt size. The w140's for example have 14mm bolts. Most other MB's have a 12mm wheel bolt size.
1989 300 TE
Thank you for the responses. That does make since on the size and offsets. I apprciate the help!
