21 - 24 of 24 Posts
· W221 & Audio Moderator
2015 S550
T3lane, bahora75, you're both fairly new here - but one thing that will help you is the W220 S-Class Encyclopedia sticky (the one that says "Start Here" in the title).
In the section that contains "Doors won't open" in its heading, you will find the following:
-- Doors will not open (Potentially a safety issue!!) - http://www.benzworld.org/forums/w220-s-class/1581788-w220-rear-door-wont-open-so.html - also see related posts, http://www.benzworld.org/forums/w220-s-class/1599005-rear-door-handle-r-r.html and http://www.benzworld.org/forums/w16...acing-front-door-lock-actuator-machine-2.html
The Encyclopedia may not answer every question - but there is a reason it says "Start Here."
Skylaw
thanks Boss
I will surf during above links and I will let you know
(by the way, I solve my shift stick problem by change the black electronic module in side the stick box
but i relocated the security ships from the old one to new one to allow security sys work again ... it cost around 100 USD)
· Outstanding Contributor
Look for this thread "W220 S-CLASS ENCYCLOPEDIA - START HERE (major update Sep 2014; minor ones frequent)" it's one of the first ones.
Dean
21 - 24 of 24 Posts
