1 - 10 of 10 Posts
2000 E320
I know this is an old topic, but I figured I would check and see if anyone out there has come up with new ideas/ways/kits to be able to use a bluetooth phone in W210.
CLK320
Tony,
I'm still looking at the Parrot CK3100, because it has the extra LCD, but I haven't purchased it as of yet. I think this will take some splicing to work properly, but all the research I've done says it should work just fine. I also have the new Audiovox SMT5600 Smartphone which I've heard works great with the CK3100.
Here is where I've found the cheapest price for the unit. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=5739836182
There are a few different brands out there, such as Nokia and Motorola, but I keep going back to the Parrot because I've heard of good reviews especially with my phone. I'm hoping to get this in the next couple of weeks and then hopefully have it installed shortly after that.
2000 E320
Thanks for the info. Do you know how extensive it is to wire this kit in the W210? Where would you install the unit with the display?
CLK320
I think I have found all the wiring diagrams for the W210 so I will see if I can use the integrated mic or if I will have to use the one that comes with the kit. I was thinking of sticking the display unit in the container below the radio headunit so that it was out of site, the only time you would really have that open is when you where in the car and it would stay closed when it was parked (out of sight out of mind). The radio mute option looks like it could work as I found the terminal in some diagrams (I would just need to figure out the wiring for that) and from the info I found there are spots for dedicated speakers for the phone system right above the side vents on the dash (I just don't know if they are already there or not and how easy it would be to get at them from under the dash). Ultimately it comes down to time and money as I'm sure I'll have the whole dash apart to complete this project. I'll make sure to take a lot of pictures during the process so to be able to write a DIY publication.
2000 E320
Discussion Starter · #5 ·
Mr. Pie,
It would be great to see a publication on the subject. It sounds like you've done the research already. BTW, do you have the wiring diagrams in electronic form? If so, could you please email me a copy or let me know where to get them? Thanks.
CLK320
Tony,
I'll have to track all of those down again, but yes I do have them in electronic formats.
2000 E320
Discussion Starter · #8 ·
Mark,
I have the Nokia 6600 and the Sony Ericcson T610 already. Both phones have Bluetooth. Is there a way to make them (or one of them) "Mercedes Ready"?
W211/W210 Estate /W209/W208
The Only Phone that is Plug and play is the Nokia 6310I ..You will need the cradle and pse...
Also the Nokia Phone is a Euro Item..It Was not a MBUSA item..But works great here!I Have it in my W210 Wagon..with the VA kit
1 - 10 of 10 Posts
