1 - 8 of 8 Posts
R230 SL350 Presnt, Past - W208 CLK230K 2000, W203 C Class, W202 C Class, W210 E Class, W201 190E
The photos are brighter then for real, but it shows what I was doing. There is a little blue LED courtesy light that comes on with the main lights in the door handle recess and one behind the door pull handle which glows nicely againts the panel and I have wired them up to the dimmer so you can ajust the brightness with the rest of the dash lights...
The instrument panel bottom LED lights have been changed from fillament bulbs to the same blue LEDS.
(I rubbed the LEDS with fine sand paper to get a softer glow)
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
With the instrument cluster that you have, you can change the colored film behind the LCD displays to make them a different color as well.
oh good idea, can you change the film on the main dails in the same way do you know?
I swapped my cluster in my SLK with one from a Crossfire and noticed that I could use either the green film or the yellow for the LCD displays. I went with the yellow. The EURO version of your cluster should be the same. We got that style in the C-Class over here.
The color behind the rest of the face is part of the face on the back. Colored lights do make it look different.
A bit late but those led's are way too bright. U can see them sitting behind the lcd's. Also the other led's are a bit too bright imo but those aren't directed to your eyes. U'll see a lot less at night because your eye will adapt to the led's.
I guess U can insert a resistor in line with the led power supply for the interiour, but about the instrument cluster I don't know. Did U use the instrument socket's to power those led's?
1998 E320, 2003 E320-wife had to have one too!
A bit late also but he said they are connected to the dimmer i.e. adjustable brightness.
1997 Mercedes Benz E320
I know that this thread is very old but how do you change the colored film to a different color, I plan on doing it to my instrument cluster where the backlighting would be a different color or do I just change the bulb and if so would that be sufficient?
1997 W210 E320 Sedan
YES.. i would also like to hear more about the replacing of colored film behind cluster. How to seperate thwe cluster plastics to get inside.
Also ...LED BULB #s or source info ? I cant find LEDs for the lower or the extreme L & R sides ???
1 - 8 of 8 Posts
