Hi Everyone,
I think I may be dealing with a blown head gasket. I noticed when filling the oil that there is a light brown creamy substance on the filler cap. The strange thing is that shortly after I purchasing the car about six years ago, there was the same type of substance--it was during the winter like now, so I'm wondering is this normal? I originally panicked and thought at the time that I had purchased a real nightmare of a problem, but a colleague of mine mentioned this was normal and eventually the gunk went away...
I've been keeping an eye on oil level and it requires about half a quart monthly and both of the leaking valve covers have been recently replaced. I had to add coolant maybe a month ago, but have yet to do that again. I can't tell if oil is in the coolant. There does not appear to be any leaks and I'm going to take off the bottom cover to do a cardboard drip test. I'm also due for an oil change which has been strictly maintained.
The coolant lamp came on a couple times during the summer, but I maintained the level and the gauge never read above 90c on even the hottest days. It has not been on in quite a while.
If it turns out to be a head gasket issue, what level of repair is necessary to tackle this on ones own? I'd really like to keep her going!
I really appreciate any help!
Thanks,
Joey
Just some basic info:
- valve covers replaced 11.09
- oil change 09.09
- current running temp. 80c
- radiator replaced 04.09
- water pump 04.09
- mileage currently at 170K
Thanks,
Joey
- oil change 09.09
- water pump 04.09
