Just purchased a used 1998 ML320 last week. Cannot get the heat to turn to cool or cold, just full on heat. By searching forums here disovered it is related to blender door issue. Removed dash, radio, etc to gain acces to the door. With the ignition on the blender motor turns to close door regardless of position of heater control. If I manually push the linkage to open the door and then release it, the motor returns it to the closed/heat position. I am guessing that something in the control is bad and therefore not sending proper signal to motor. How may I test to confirm this?
Also found a plug with red wire and brown wire that originates from the main cabin wiring harness in the area behind the radio that was just dangling and not connected. I cannot locate where this plug might need to go. It appears it was connected at one time. Wondering if this might be related to the heater issue?
