Hey guys, wanted to get your opinion on these rims. My car is black. I also wanted to know if you think they will fit my car 95 E420. I think the tires are too low profile, but not sure. Seller says they are 7.5 wide all the way around. What do you think?http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=66483&item=7964817541&rd=1
1987 Mercedes 300e
i know 7.5's and 8.0's will fit in the front. 8.5's can fit in the rear. any higher will cause rubbing. i think you are fine. tell us how the purchase comes along and those rims look nice. don't leave them dirty :D
2006 S500 AMG Wifes Rig Hillbilly Girl 02 ML320
Hey Nathan ! Thought ya died and the hogs et ya!![:D][:D][:D][:D][:D][:D]or is it you just can't get out of that E 420 of yours!![:D][:D][:D][:D][:D]See yer buyin some bling bling!!!
Smokie
Yeah Smokie, spring is almost here so I need some Bling bling, my wife is not so convinced tho:) I like these rims, something different, but this rim, tire size thng is driving me crazy. They are on a W210 and I think the tires are too wide. The owner is not long winded with his responses. I don't want to drop a grand only to find out they rub like crazy. But, man these are sweet rides arn't they!
It's all in rim width and offset! You get right offset you should be ok! Drove me nuts to![:(][:(][:(][:(]I just made sure my overall dia was same as stock as not to mess up gear ratio and speedo!!
Smokie
Judging by the size (17) those AMG AERO II's should be on a W124 since the W210 is supposed to have 18's.
I wouldn't be worried about the width too much 7.5 is within the limits of a 124. However you should look into the offset of the rim, here are the original specs for a 1994 400E, use them as a guide:
Bolt Pattern: 5x112
Offset Range: 35 to 40
Wheel Size Range: 16x6.0-20x8.5
OEM Tire Size (Front): 195/65-15 (195x635 mm)
Hope this helps.
