C36 C43
[}:)] i was wondering if you buy the grilles black or if you have to paint them yourselves? And if you have to paint it yourself what kinda paint to use
1995 C36
i believe you have to paint it yourself. i have a stock grille and i painted the inside ...
i believe you have to paint it yourself. i have a stock grille and i painted the inside part black. Just used car spray paint and clearcoat. =) As for the metal frame im not sure.
Re: i believe you have to paint it yourself. i have a stock grille and i painted the inside
Painting the chrome will be different. You need to de-chrome it first and then paint them.
SL320, C36
This is kind of a late reply, but hopefully it will help future readers.
The easiest way to "dechrome" front grills, trunklids, etc is by way of applying a black self adhesive vinyls. You could buy this vinyls at any sign shop.
3M or Avery brands should be good enough.
The clear advantages of using this self adhesive vinyls are:
easier to apply than paint
easier to remove (the adhesive on the vinyls will not leave a sticky residue on your car, when you remove it)
cheaper
