1 - 11 of 11 Posts
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Seems I have been a little to silly with my Benz..and the flying lessons on country roads at high speed.. my indy did a service on it on friday.. and informs me i need a new sump pan..because I have cracked mine just behind the sump drain plug...due to a takeoff and a heavy landing over a hump back bridge...Anyone know where i will get one from ?? Except my local stealer.. who needs his carribian vacation next month....Is it the same as the 320?
1995 S600 (sold)
Have you thought of trying a special purpose epoxy to repair the crack? There are some very good ones out there that would work. 3M's Scotch Weld comes to mind...
http://www.mpsupplies.com/3mScotchWeldAdhesive2216.pdf
Thanks but..
Dont want to risk it..
do the job properly..
or suffer the outcome...
DRY SUMP...
NO ENGINE....
S600L
Just checked my S-Class book and compared the cross section of all 5 engines and unfortunately its one of a kind for the V12[:(]Looks like its time to bite the bullet at the main stealers[xx(]Would be nice to know the price[:0]If you ever damage your front grille I have a brand new one in the original packaging(£360) - but will do a deal for you - just something to bear in mind as im in no hurry to get rid of it[;)]
S600, ML55
I belive the pan is a aluminium (aluminum) alloy.
It could be weldet by a professional welder. The cost should be relatively low compared to a new pan. Yes you have to remove it (anyway) and cound not drive your benz[:(] until the pan is done.
Steel pan.. otherwise it would have shatterd
so no welding or sticking or snakeoil fixes .. just a new one or a secondhand one...
94 s420 98 s420
Merc600sec - 5/8/2005 7:51 PM
Snake oil? theyre only trying to help so you wont have to pay for the "stealers" vacation.
bass1175 - 5/9/2005 1:55 AM
Yes I know but....
I will do the job properly or not at all...
so no quick fixes..
the only thing quick here is my V12 Benz
S600L
Oil sump pan :-A 120 010 19 13 @ £49.71.non in UK 25 in Germany
Gasket for sump pan :- A 120 014 05 22 @24.23 available in UK.[:)]
Discussion Starter #11
mercS600 - 5/9/2005 10:34 AM
See if you ask the right question on here .. you will get the right answer..
THANKS MERC S600..you are a star.....
1 - 11 of 11 Posts
