1 - 8 of 8 Posts
2000 S320
hi all.. my cars old owner upgrade headlight to bi xenon.. i realise that my auto level isnt running... i found cable which is not plugged to the headlights...
i realise that i need a small convertor part from your old posts... today i bought this converter and plug them to the car. (blue to 4, black to 3, red to 2, and green to 1.) but nothing happened...
where did i make a mistake :confused:
2001 S430
Check for pulled fuse maybe? or blown? has it been disabled via DAS, or do you have to enable it. Did it come with adjusting for your car on reg lights?
2001 S430
P.S. cable does not work if is hooked up to your laptop. Just kidding just looking at picture and saw keyboard.
I'm confused- your pic shows the plug next to your computer. Is it in your car, and how is it attached?
What did you expect to 'happen' when you plugged it in?
2000 S320
Discussion Starter · #5 ·
:)) you are right... i unplugged it after i try..
i plugg them and then i turn on my lights, i raise and lower the car and there are no adjustments seem on headligths
2000 S320
Discussion Starter · #6 ·
last week it gave "auto level error" (i think because of cables that are not pluged) on star diagnosis...
should i erase error logs or should i calibrate it from diagnosis to make them active :confused:
2001 S430
Erase then recalibrate, Again i have no experience, but first thing I would do is find out if the car came with adjustable lights? then clear errors, after that install the lines if that is what they are for? then use star right away to enable, If you throw a code after that I do not know what to say. This is just another opinion from a different guy, Do not take it as in written in stone. I am just the next store guy who like to trouble shoot.
2000 S320
Discussion Starter · #8 ·
i should go to workshop to erase and recalibrate them :(
1 - 8 of 8 Posts
