1 - 15 of 15 Posts
2006 E350 (1/2014-Sld), 1997 S320 (5/2014), 1995 E320 Cab (1/2015), 88 560SEC (2/2015), 90 560SEC
I know all years are best years of SEC. I personally like 1989+ for the passenger airbag. Maybe it can be retrofitted in old cars? I dont know.
What do you guys think? Which is the best year of SEC (according to you) and why?
Thanks for indulging me.
95 C280, 89 300E, 94' E320 Coupe, 91' 560SEC
Guess who has ASR!!! Hahaha I actually love the damn thing in the snow, keeping the rpm right where it should, but it's not 100% On as the previous owner replaced the rear calipers and didnt get the correct ones where the sensors bolt on. ASR can be a headache if you don't know how it works, or if you wanted an LSD.
1991 560 SEC 1994 E500 2014 E350 Cab
I am partial to 1991, the last MY as it was the fewest. NON-ASR, and I am aware that some were made in 92, in S Africa.
Reactions: wooky_chew_bacca
'89 560SEC, '90 560SEL
I'm going to go with 1989. It's got all the updates and options you would want (well, ok, minus the rear seat rolltop), and beyond that I've got a growing feeling that the 80's was a cooler decade than the 90's. Doesn't hurt that my SEC is an '89...
1985 300SD 1988 560SEC 822 1976 450SEL 1981 300SD
Euro '88..
...biased, yes...LSD not ASR, Code 822 option available, year with the most KW...still has a glovebox, stringbacks on the front seats...
87 Euro500HVSEC. 88 Euro 560HVSEC. 89 Euro 560HVSEL
Yes i can vouch for that with my two
The 560 Euro is a late 88 that captured all the fruit including the better seats but leather map pockets (not nets) 300hp engine with no cats / 2.65LSD / adjustable steering position an memory seats and glovebox (no passenger airbag thank goodness as no issue swapping out the steering wheel) /no ASR
Anti-dive/squat rear suspension/alloy trailing arms/rear SLS
The Euro 500 M117-965 high comp is just as desirable as that engine is real sweet and luvs to rev. I now have a very desirable 2.65LSD to drop into that and also have upgraded the seats to the later version. Being Euro also has the anti-dive/squat suspension /alloy trailing arms/ rear SLS
Both now have the rear roll top burlwood seat storage box swapped in (in addition to the matching front burlwood storage box)
I don't think they come much better than the Gen2 Euro version in both 500 & 560 with the slimline Euro Bumpers and no ugly coin tray along the bottom of the dash and no ugly USA sealed beam headlights and no anti-pollution gear
· R.I.P. Never Forgotten
1983-2007 MB's
Owned two euros a '86 500SEC and '90 560SEC euro.
If I were to get a Gen2 euro again, it'd have to be a 86-87 560 ECE version w/ the 4-pin EZL.
I would have peace of mind knowing my car could last for the long term without expensive and hard-to-find 8-pin EZL repairs.
I would do updates to the car for the later 90-91 interior if I needed, but to me, mechanical peace of mind coupled with 300hp ECE trumps all.
'91 560SEC, '91 300SE (sold), '98 Yota, '02 S-10 Hauler, 1961 Albright Cabin Cruiser
I agree on the 1991 also because of being the last year and being rarer due to the lower production/sales run
"Upgrades" can be made if you can get your hands on the needed parts, Euro headlights and bumpers for starters
Bondavi this won't be a problem soon
http://www.benzworld.org/forums/w126-s-se-sec-sel-sd/2180361-m117-mods-bluetooth-cis-k-jet.html
Progress on this FrankenCIS & FrankenDPS Kit for KE-Jet has now mastered control of the fuel mapping which now totally tuneable across the whole rev/load range.
The ECU has a lot more functions than just fuel
Mike from Dkubus together with Steve from reanimotion are all over this Bosch system (which by the way is it turns out with a bit of modern technology adapted to it is actually a "very good system")
This assumes a non molested EHA and a good Fuel Head / injector filters are clean / Good POT / no vac leaks / fuel pumps are good / Fuel reg is good / so what is aimed for is the engine is already working fine and tuned correctly as a starting point for the Franken to take over from that point.
It is not designed to mask a poor running engine that needs attention
Next step is working on the ignition mapping and the R&D will be done on that to phase in control of the ignition ( I assume this will eliminate the need for reliance of the EZL for any mapping- and most likely eliminate the need for the outdated EZL altogether)
I have a haltech 2000 which has extensive ignition mapping tuned for a Euro high comp 560 300hp (with the 16/17-24/25 cams as both same profile) and this will most likely be used as a basis reference for them to work from as a starting point.
End result will be a huge leap for the M117 i believe to finally prove how good this engine is in its current form without the need for a full EFI conversion to wake it up
Discussion Starter · #14 ·
So 1986+ 560sec's are ok cause they do not have the 8 pin thingy?
1 - 15 of 15 Posts
