1 - 9 of 9 Posts
1991 190e 2.3 auto burgandy
hello all,
i recently purchased an 1991 MB 190e 2.3 with 232,484mi previous owner blew head gasket on aug 4th and shut car down asap and had towed.. car will start and drive..and im wanting to order parts. i know it needs a new head gasket. what other parts need replaced when doing this and where is the best place recommended purchasing them.... thanks Nate
2000 C230 Kompressor, 2005 Volvo S60 T5 AWD, 1992 190E 2.3 -Totaled
For online purchases I prefer Autohaus AZ or Peach Parts, I have ordered several things from both of them and they have all been the correct parts, and functioned perfectly.
98 SLK230K AMG, 98 E55T, 89 2.5-16
nice car! my 2nd favorite color after white. Almandine red is it? as you will pull down the head you might as well replace the chain and its accompanying accessories to take advantage of the downtime.
regards,
1993 190e-2.3
I use Autohaus AZ and am happy except for the 7-8 day wait for my parts. My 93 190 2.3 blew its head gasket at about the same mileage as yours.
I replaced the gasket-set, head bolts and washers, and the upper timing chain guide only. My timing chain tensioner was replaced years earlier, so I reused that. Mine never overheated, so I just cleaned the surfaces only, and put it back together. 14 months later and the coolant level is exactly the same. And my oil consumption is much better. I'm happy with adding a quart every 2,000-2,500 miles.
New exaust manifold nuts too.
And my coolant was going into the engine so my cooling system was clean. If your oil was going into your cooling system, then that contaminates the cooling system. This makes more of a mess, that I did not have to deal with.
1997 Dinan BMW M3; 1985 190e 2.3, 2013 Jeep Wrangler
93 190E 2.6; 82 300 SD Turbo
PartsGeek.com
AutohausAZ.com
AutopartsWay.com
Are ones that I use. APW is usually cheaper than the other two.
1993 190E 2.6 AMG "Alma", 1990 190e 2.6 Black, 2001 230SLK Magma Red
SAME color as mine. Very nice color! :D
+1 for AZ Autohaus and I am pretty picky about parts brand. I may use a few other sources like the stealership (with my MBCA discount)depending on what I need. I have used partsgeek, parts.com and some from Napa but I really try to keep to the OEM vendors and the 1st thing I look at when I get them is where they were made!
Parts.com is awesome. When you buy Mercedes products from there, they're actually from Mercedes-Benz of Naperville, IL and ship from either the IL or NJ Mercedes warehouse or if need be from Germany. Always excessive packaging though.
1 - 9 of 9 Posts
