1 - 11 of 11 Posts
1980 280 SE Euro
i was wondering what is the best oil to use in your 126. i went to the DIY guide for it on this site but still not seeing what i wanted to know or not understanding hte verbage. if anyone can put it into lamens terms. best type of oil (co) and what weight. can you ise sythetic on older cars. my 280 se has almost 400KM but hte engine was rebuilt about 1 1/2 yrs ago. so there is about 20000 KM on the rebuilt engine. jsut want to get the most life andperformance out of the engine. any suggestions will greatly be appreciate
89 300SE
Hotly debated topic. Many posts regarding this issue on this forum. I do not think there is a "best oil". There are many good quality oils that meet the manufacturers criteria. On my 300SE I use Shell Rotella 15W40 year round and replace the oil between 3K & 4K miles.
1985 500 SEC, 2005 E320
same here. except I use Lucas with it. however, some debate the usefulness of it. I used it on my sebring and went 150k and the motor looked and ran as if it was brand new. that says alot. Chrysler leaves a bit to be desired on longevity.
Depends on the day!
15/40 Rotella or 20 50 is great..however w/ the drop in zinc and phosphate levels I would recommend putting in some additional additives. There was a thread on this just a couple of days ago. If your engine doesn't leak I'd run M1 20/50..It's served me very well in my white and black coupe as well as my AMG. Again, you'll still need to add to what ever oil you choose to run to keep the additive package close to what MB had in mind when they designed our cars. Jonathan
Chrysler Sebring
Just wondering which engine you had in your Sebring? I have a 1994 Plymouth Acclaim with 147,000 (Mitsubishi 3.0 V-6) and have religeously had the oil changed at the Chrysler dealer every 3,000 miles. I can't say that it still runs like new, but it "still has plenty of power" according to the tech who always works on it and just test drove it.
He has never recommended any oil additives (he likes BG 44K for the gas however and they make a MOA too), but I have never brought the subject up. There are a few people on here who use, and seem to like, the Lucas products.
1980 280 SE Euro
Discussion Starter · #6 ·
thanks guys for all the advice. i have been puting in 10w40. i have t change the weight i guess. also i go through alot of oil. i put a quart in about once every month or so. is this normal. i don't beleive there is any large leaks, just the usual, i guess for a 20+yr old car.
it was a 2000 sebring LXI convertable. that's all I remember. I had it since new. it's been gone 2 years now
a quart a month would make me crazy. It's not unheard of, but not very good either. I don't use any oil. Fortunately, or at least it's less than 1/4 quart every 3k.
1991 300 SE
Wow, a civilized (to this point) oil thread...
That's a tad light for AZ. Like me you can use 20w 50 year round, that may slow the oil use. A lot of high-speed driving in the heat can cause higher oil consumption as well. Use an OE filter, that's more important then the oil brand, imo.
1980 280 SE Euro
Discussion Starter · #9 ·
wow a 20/50 weight. that might be why. i have been using 10w40. i do most of my driving on the freeway and never really below 55mph on surface streets. 40-45 doesn't even feel like im moving
1981 240D - 4spd manual, crank windows, more than 400K miles and one squashed driver's seat!
Wow - you must blow by those "Children At Play" signs...!
1 - 11 of 11 Posts
