1 - 14 of 14 Posts
Looking for suggestions on a good motor oil for my 04 E500 4matic . I'm leaning towards Mobil 1 5w-30 , I think that was mentioned in the owners manual
thanks !
'04 SL500; '05 E500; 05 E320 Wagon 4-matic
When using Mobil oil in the Benzs, I only use 0-40 European formula (available at Walmart).
I believe that's what's recommended for that car. that grade has served me well for many Benzs over many years actually.
I went with mobil 1 European 0w-40 - should I expect to get 7 ,500 miles per oil change with this formula ??
Purple Moderator
You will be able to go up to 13,000 miles safely.
Use the Mann or MB fleece filters and the car will tell you when to change the oil.
2000 S430, 2003 S430, 2000 S500, 2003 S600 TT, and 2005 E320 CDI
I use the fleece filters and Mobil-1 0W-40 FS European Formula, too. Given its affordability and availability, there's really no reason not to. My oil change regimen with our M113 engines is every 5,000 miles. The longest I will go is 7,500 miles. Yes, that's before the car will tell you to do an oil change.
E63AMG, SLK32AMG, Ferrari 348 Spider, R350 Bluetec, Eagle Talon TSI/AWD, Jeep CJ7, Smart EV
I used Mobil 1 - 0w040 euro formula for years but recently switched to Pennzoil Platinum 5w40 euro which is MB229.5 approved too! It's base is derived from natural gas. I've had no issues.
Always use a Mann filter.
J
2005 E320 4Matic Estate Wagon
thanks !
As I think has already been mentioned - after a little research and consulting the manual, it seems Mobil 1 0w-40 is the best option.
2000 SL500, 2001 S600, 2004 E320
0-40 or 5-40 of course… if you want to go by the book. If you want high performance motor oil…
Mobil1 5W-50 or… Mobil1 0W-50, racing oil.
I've been using 5W-50 for few years. Not available at local outlets, at least I can't find it, which actually makes shopping for it much more convenient AFAIC.
To me fleece filters is ok when you come to oil hardex is good it work for hot weather and coold weather
Purple Moderator
I have heard of Hardex, but it appears its availability is limited to Asian areas and Pacific islands near Asia.
1 - 14 of 14 Posts
