My car is Mercedes Benz w221 s-class (S 300 - 2011):
General Data
FIN: WDD2211541A364104
VIN: WDDNG5EB5BA364104
Model Year 2011
Model S 300
Engine 272946 31 683691
Sometime during I drive the car all the dashboard alarms lights getting on plus alarm tunes. In addition, during this fault, I still can drive the car normally but after I stopped and switch off the car will not start again (like car engine starter not start or main battery damage).
Therefore, I need to remove the main battery positive connector, and then reconnect back after one minute, and then the car will work normally.
Kindly could you support me how to solve this issue?
Discussion Starter · #5 ·
It sounds like you briefly lost all accessory power. Is any corrosion visible anywhere? Battery terminals, ground locations, positive terminals near battery, fuse boxes?
I check and I could not find any thing but electrical technicians may can find what is going wrong and why the car will start again without any issue when I remove the battery cable and return back
