1 - 1 of 1 Posts
Does anybody know of a good Benz repair shop in San Antonio. I have a 300DT that is having tranny trouble. It will only shift from 1-2, 2-3. And when it warms up it will only shift from 1-2 at 3,800 RPM unless you shift it into neutral then back into drive. I have removed the EGR to eliminate any vacuum leaks there. I have also adjusted the vacuum regulator and the bowden cable. All of this happened when I removed the engine and tranny to swap out the engine due to a bad rod bearing. I am in the middle of moving and converting my '93 F-250 to WVO. Thanks for everything. JT
1 - 1 of 1 Posts
