1 - 8 of 8 Posts
1985 300D
Grrr... I have installed a new radio before, but how on earth do I get to my original Becker Radio (which isn't working properly) in order to repair it, or to install a new, improved version? I just can't seem to get to it to pop it out or disconnect it.
I drive an 85 MB300D... I doubt the Turbo has much to do with this =)
CLK / ML
I guess you mean remove it ?
You need radio keys (about $8) or two thin metal strips.
Insert into the left and right slots of the radio. Move the keys inward to release the lock and pull out.
G320 & E500
Radio Removal
In order to remove the radio, you have to remove the two screws below the ash-tray. Then there will be two tabs to pull down below the corners of the radio. It will then slide out with no problem.
Chuck
1984 300TD
Re: Radio Removal
Hello Chuck,
You look like the guy to ask a radio question for a mercedes....I have a 84 300d radio that I'd like to switch out with my old 86 300e radio. I know the 86 radio had a code...but am not quite sure about the 84 needing one. Any ideas? Should I "chuck" the whole thing and get a different radio than the dreaded Becker?
Thanks!
Elaine
Chuck
Mercedes Diesels
the beckers are popular on ebay, often not easy to find working and inexpensive.
John Gregg
84 230CE & 84 300DT
I have a working one that I pulled from my '85 to put in a CD player. I'm not sure what it...
I have a working one that I pulled from my '85 to put in a CD player. I'm not sure what it would be worth if someone was interested in it.
82 300D, ISU Formula
Getting the radio out isnt too hard, but the wiring can be...
Theres a couple of plates that slip over the threaded end of the two adjustment knobs (If this is your type of radio) that you have to remove after unscreweing the volume and tuner adjustments. The Haynes manual describes the process pretty well. The wiring can be tough if you are used to the typical wiring harness of today. Have your multimeter and a small battery ready to test which speaker wire goes to which speaker. Isnt it great though that the radio is a standard DIN size? Most early German cars were this way.
1 - 8 of 8 Posts
