SL500 1993
My Becker radio stopped working and displays the error code E2. I have been told it might be due to a old electrolytic capacitor failing in the system. However, does the E2 code provide any specific information about what part of the radio has the fault, ie. the amp in the boot, the CD changer or the tuner in the car. Doe anyone have a list of the fault codes and their description? I have attached a picture of the radio. I understand my radio design was used up to 1992 although my car sold in Australian has manufacturing day June 1993.
2616885
2002 Black SL500, 2000 Azure blue SL500, 2005 Silver (A209) CLK500
"E2"or "E3" (Without CD Changer)
1 Input Power to the RECEIVER UNIT (Trunk mounted) is missing, Check with volt meter to test for 12 volts
2 Fuse of the RECEIVER UNIT (Trunk mounted) is open, Replace it with 7.5 amp fuse.
3 The BUS CABLE (gray colored) that connects to HEAD UNIT(dash mounted) to the RECEIVER UNIT(trunk mounted) is not connected or is defective.
4 RECEIVER UNIT(trunk mounted) is defective.
"E2 or "E3" (With CD Changer)
1 Input power to RECEIVER UNIT (Trunk mounted) is missing, Use a voltmeter to test for 12 volts
2 Check the RECEIVER UNIT for an open fuse and replace with 7.5 amp
3 Input power to the CD CHANGER (Trunk mounted) is missing, check with volt meter to test 12 volts
4 BUS CABLE (gray colored) is defective or disconnected,
5 CD CHANGER is defective, Disconnect the CD CHANGER from the HEAD UNIT, if the E2 code disappears, Replace the CD CHANGER,
6 RECEIVER UNIT (Trunk mounted) is defective.
SL500 1993
Thanks for the info. Working on that now. I have traced down a repair manual for the radio/tape drive in the car but not the amplifier in the boot. Still trying to find that. I has a Becker model number but only the dash radio data is popping up.
