G
Guest
·I purchased my Becker 2662 from SW Stereo Specialists out of New Bern NC. Their tel.# 1-800-270-best. <br>The unit comes with a mounting bracket that screws right into the existing holes on the support bracket<br>next to the right wheel well where the c/d plyer mounts. If your radio code starts with BE, its a becker headunit, if Al, it is an Alpie unit. both work with the Becker 2662 but with the Alpine head, the randam shuffle does not work. The unit is fairly easy to install and the adapter plug is set up so that you can not reverse it. The power cord goes directly into the unit. I have had mine over a year and no problem. The Alpine unit that M/B uses has a plastic case, that is one reason that they have a mounting box surrounding it. The Becker unit has a steel case surrounding it. You can also go to the Becker Board if you have any questions. The Becker Unit with the bracket was appox $425.oo if i remember correctly. I have been very pleased with it. BTW, don't worry about the fibeer optics, the only way for those "wires" to get screwed up is if you kink them.
