1 - 8 of 8 Posts
1992 500SL 129.066
Hello,
I have bought a BECKER 1432 for my 1992 SL500. My car has a ALPINE SYSTEM and i want to use the original one with the AMP in the trunk and the other AMP in the passenger area.
Today I connect the BE1432 to the car and in the screen appears the word CODE. I insert the 4 number of the CODE and nothings happens. The screen is empty. No word or light.
What is the problem? Have i to push any button after the 4 digits?
Is there anyway to check ( with a POLYMETER) the radio and the AMP?
Best Regards and Thank you
Luis
1992 500SL 129.066
Hello
THANK YOU LEWISMEND
Does anyone know how to check the AMP of the trunk or the connection diagram of the AMP?
Thank you.
Luis
1992 500SL 129.066
Hi,
I have some questions,
1.- When you push the code in the radio, the amplifierneed th esame code, in other words, Is it possible that the radio and the amplifier don't work because the radio has a code and the amplifier has a different code.
2.- What is the typical porblems of this type of amplifiers?
I thank everybody for the anwswer of the questions
Best REgards.
Thank you
GLE350 / 2017, E350 coupe / 2014, SL500 / 1997
Hi,
Best REgards.
Thank you
There is no code for the (Bose) amp, just for your radio. And I am pretty sure is is a 5 digit code, it is on mine at least.
1992 500SL 129.066
Hello,
finally, my BECKER 1432. I had check/fix all connection, but it works. Right now I waat to install a YATOUR CD EMULATOR. Anyone knows how to do it? What I need? Is it only to coonect the yatour directly to the tuner?
Best REgards and Thank you.
Luis
1992 500SL 129.066
Hello Pazo,
I do not know if i can add a link here to another FORUM so I will send you a PRIVATE to show to you.
Best REgards.
Luis
1 - 8 of 8 Posts
