95 E320 Cabrio Black/Cream/Black - DEXRON6 - Iridium Plugs
And head lights are not working properly as well. Has any one experience this electrical issues after removing this items?
Yes, the wiring hardness was replaced 3 yrs ago.
TIA
W124
Are you sure none of the wiring left open when you deleted all of these accessories is exposed and shorting to ground? Check it all to be sure.
Yes, some of the connector are exposed to the environment after removing the pumps and motors. Any tricks to isolate the short?
W124
^ This is a great place to start. Once you find this doesn't have an impact, reinstall your deleted components one at a time, and days apart from each other, to see if there is a positive impact of one particular accessory on your problem.
Thank you fellas!
W201 Moderator
89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
I'm guessing you lost a ground in the process. Make sure you have ground from the headlight connector to the chassis.
