Hi Fellas im in for some help, here in Michigan it got so cold that the Battery is so Dead that the Dome Lights dont lit any more , i didnt turn the car on for 2 day and this morning i could not get the trunk open even with the key
so what to do i need the car on the road asap ..
The boot should open with the key if not try getting a charger that you can plug into the lighter socket that should give you enough power to get to the battery.
Thanks NZ_Benz but i got it figured out easier and i think faster way too_On the Passengers side carpet where you rest your feet but 1st you have to remove the carpet, then there is a Aluminum cover just undernith ac filter remove that and you'll see bunch of wires but theres only one you need A+ one ....
