1 - 17 of 17 Posts
E200 W212 2012, SL500 R129 1994
Friends, i have this thing missing. I have ordered all three parts, but cannot get how it's working. The part N62 is connected to the body - it is clear, but where part N59 goes? I have only idea tha it is connected to the N56 from the opposite side of the part N53, am i correct? Can someone give me directions or make a photo of yours?
1996 SL500, 2000 E430, 2011 E350
Heh I just ordered those parts a few weeks ago because I over-tightened #56 and the shaft broke in the hole of #62 .
#56 fits through the lining - #59 fits on the other side of the lining through #56 keeping it in place. You will see where #62 fits on the body - that is the mount for #56 and holds it. I will take a picture tomorrow if my description is still confusing.
1999 ML320, 1998 SL500
S500 battery panel fastener
I have yet to find any combination of parts that work together. As long as the panel doesn't fall open I'm ignoring the problem.
1997 SL600, 02 Explorer, 00 Harley Heritage Softail, 89 Thompson 24' W/350 Hp Merc Cruiser
Wlb50....well son of a gun.....my #56 is also busted off in #62 . I would like to order the 3 parts. Can't be that expensive. Do you have the MB P/N for the 3 parts in question? (#56 - 59- & 62) Thanks in advance G
I couldn't resist....:devil :eek
Fresh venison from the last hunt, Mossburg 12 GA. 6 shot pump, Elvis decanters with 80 proof Kentucky Straight Bourbon. (I'm not too much of a drinker...they're collectables but I do like my Venison) :grin :wink :angel
Wlb50....well son of a gun.....my #56 is also busted off in #62 . I would like to order the 3 parts. Can't be that expensive. Do you have the MB P/N for the 3 parts in question? (#56 - 59- & 62) Thanks G
I think that breakage is pretty common - particularly with this infamous plastic as it ages. When I broke mine I was certain that I would either have to live with it broken or comb the wrecking yards for a new cover. (I'd hate to price out a new cover!)
Just for ducks (what does that mean, anyway?) I went to my friends at the parts counter at MB-Sacramento and to my surprise all 3 parts were available - which tells me there's a whole lot of breaking going on, from Moscow to Sacramento ;-)
Anyway here are the part#s:
129-693-01-56 Button
004-990-52-40 Washer
129-693-00-68 Nut
you really have to be careful tightening these - just a bit snug
whole bill for me was $14.04
I don't remember the part numbers but when I bought my used '98 SL500 while still in California I went about fixing all the minor issues. I went to the dealer and bought the parts for that panel, but they didn't work as a set. I then went to a junk yard and got a set, or part of a set anyhow. Still don't have a working latch and really no longer care.
I'm glad someone was able to get a working combination.
97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
I replaced #56 with a handy button (pic below) that I found at Home Depot. I removed #62 and enlarged the plastic receiver's hole to mate the metal thread of the button's screw and reinstalled it back. IIRC, the button with metal screw cost around $3.
Great Idea
Well I was going to go with Wlb50's solution & go to the dealer but then I saw your solution & thought what the hay....."that'll work".
So here it is: took the female receiver out of it's metal holder in the trunk. Drilled out the threaded plastic nub (it came out very clean & didn't damage the threads)
Bought the first knob with a 1/2 " stud (too short). :eek
Went back to Lowe's got the 3/4" stud ($2.82). Everything fit like a glove & the battery cover is as snug as a bug in a rug! :grin
So Wlb50 & edcarls thanks for the info & solution to my little problem!:grin
Battery panel parts
Ad man, I think you found the correct German made button. Now I need to upgrade my URO button.:laugh
Surely someone has found a combination of parts which work together.
In my case, the dealer (while I was still in California) gave up after selling me the "correct parts" and refunded the money.
It seems to be a problem at such a low level that MB has abandoned working on a solution. There must have been cars that came out of the factory with a set of parts that worked, but when they failed they never created an accurate parts list for that area.
I just gave the correct solution - parts fit. Back on page 1.
129-693-00-68 Nut
1 - 17 of 17 Posts
