1999 ML320
First, which battery do you recommend?
This one:
Zip Code Entry at PartsAmerica.com
or this one:
AutoZone.com | Shopping | Zip Code
Also, I was told that when they change batteries at the local shop here, they use a "memory saver" for the radio. They said it works 90%-95% of the time. Do you know if this works for the ML320?
I don't have my radio card. I called MB and they said to just go to one of the dealerships with a proof of ownership to get the code. I'm just trying to save the hassle.
Thanks in advance.
2002 ML 500, 1994 Ford Explorer donated to Doctors without Borders
I would just get the radio code. You're going to need it sooner or later and you won't have to worry about whether or not the "memory saver" works. It seems easy, just do it and never worry about your code again.
98ML320
And while your there buy the Benz Battery which fits perfectly and is competitively priced. Also, I'm pretty sure it's the only battery on the market that works with the cars battery safety strap/mounting hardware.
By the way, your links don't work.
Call MB Roadside assistance - get the full deal
MB Roadside assistance will deliver and install the correct OE battery, including all radio code and reset issues...
The last time the ML battery was changed I am sure it was under $120 for the full deal...
'03 ML350
yeh, just use MB Roadside and they'll come to your home/work and install the battery and get the code for you. it was about $130 in SF.
