1 - 9 of 9 Posts
c320
hi there
my c320 every now and then gets a bas warning light. Have had this checked and it was nothing and all brakes are fine but when i go over a bump (not all the time) it pops on.. is this a common fault? its a 2000 c320?
thanks!
C220 CDI T A & A200 CDI A
Before taking it to dealership (if you are not under warranty), I would check the brake light switch. If the switch is not working perfectly, you get the BAS warning.
2004 W203 C180K Elegance Sport Sedan & 2005 W209 CLK280 Elegance Coupe
i had this problem before also. its a very common world wide problem on 01-03 cars. its a faulty wiring loom and the dealership can replace this under warrenty in under an hour.
after that is done, its perfect
W203 modified
mobeyone - 3/18/2005 4:13 PM
hi there
thanks!
Bearing in mind all of the above posts are more likely, I did in fact have a faulty sensor at one wheel and it sent ESP and BAS into a tailspin.
It was a yaw sensor intended to detect understeer.
c320
brabus - 3/20/2005 2:55 AM
thanks for all the above guys!
its due to go in for service a shortly so will save it till then.
re the above,, where is the brake light switch located? and can i do this myself?
thanks!
what is the brake light switch you are referring to?
and no i dont think you should do this yourself, better get the Merc ppl to do it under warranty
c320
eerola - 3/19/2005 5:29 PM
hi i was referring to this post?
thanks!
mobeyone - 3/20/2005 8:07 AM
...where is the brake light switch located? and can i do this myself?...
Brake light switch is usually located next to your brake pedal. I have not accessed it in my C, but I have worked on it in my wife's SLK. It is a module (about $10 or so), replacing it is very simple and safe. It can be done by anybody who knows how to use a torx screwdriver (the panel under the dashboard has torx screws).
If you do a search to BenzWorld with "brake/ stop light/ lamp switch" and "BAS/ ESP", you will find some project stories to give an idea about the work. They are not neccessarily for the W203, but I believe they can be applied pretty much 1:1 to the C too.
1 - 9 of 9 Posts
