21 - 24 of 24 Posts
Drew said:
Stop by your dealer if you can, and show it to them. They may be able to squeeze you in. I think that it's likely a switch problem. Mine came on once and then went off after starting (and didn't show up again). They ended up replacing the a switch and no lights since.
I agree. I've had this a few times with my E, my 320 and my 500. Sometimes is the ABS/ESP/BAS, sometimes not the ESP and sometimes not the ABS. In some cases it'll lock the tranny shifter. In any case the solution was either a faulty brake switch, steering sensor, the ABS cntrl unit, and, believe it or not, at one time they had to replace the trip computer - this was the one that involved the tranny lock on my 50 500.
ESP
Dears, I need help pls. I have Mercedes Benz E430 2001. I am facing a problem since I removed the middle mufflers. The problem is once I step hard on the speed accelerator , the RPM will move till it reaches 3 and can't go further and then the ESP light goes on asking me to visit the nearest workshop!!!
but once i restart the engine everything back to normal.
Can anyone tell me what is the problem and does it have anything to do with the Muffler??
· Outstanding Contributor
2006 ML500 2002 ML320
You are in the wrong forum. Try this one.
http://www.benzworld.org/forums/w210-e-class/
21 - 24 of 24 Posts
