I took the ML to the shop with no answers, yet. They found several codes related to ESP, BAS, and yaw rate sensor, but are not sure which one is causing the problem. Sounds weird.. This is not a dealership, so I am curious if they use the same software.
Here's the question: Is it possible to remove a relay temporarily to drive the ML? What's happening is that the BAS/ESP engages with no warning or lights. My wife freaked out yesterday driving into town.
The import shop mentioned that the ESP module would run $1200 parts / labor. I suggested replacing the Yaw Rate Sensor first, which is the cheaper option. I would put it in myself, but someone mentioned that it would need to be calibrated.
Any suggestions are welcome....
