I have a 1999 E320. About 1-2 months ago I turned the car on and got the BAS ASR light illuminated on the control panel accompanied by the ACC.SKID CONTROL ASR message and the engine jolting. Turned off car, removed key, tried again and started fine.
Recently, it takes up to 6 times starting and restarting (taking key out and putting back in each time) before it starts normally. And then it drives perfectly fine! Yesterday, i must’ve tried it 40 times ... finally had to drive home from grocery store in “limp mode” about 10-20 mph.
this morning, it started fine on second try.
I inherited this car when my dad died, I’m a single mom with not a lot of $$ just trying to get some advice before I take it to local mechanic monday to see if he can help,or if it’s a Mercedes Dealer only kind of issue. Thanks so much.
SB
SuperModerator
1986/1990 W126
Hello. Welcome to the forum.
Best check the designation of your car and post this in that section of the forum.
This bit is for Recommended Repair Shops. Good luck and hope you get sorted.
