farrahpleasants2015.........do as Deplore said.
If you need to replace the serpentine, a new one is only about $30 and a very quick and easy repair. Especially on your CLK 320 engine, where there plenty of room to work. The labor is just releasing the tension on the belt tensioner and slipping on the new belt.
I would strongly suggest checking the idler pulley (a.k.a. guide pulley). It's a small plastic pulley with a single bearing and very commonly fails (e.g. pulley cracks and disintegrates or the bearing seizes, causing belt failure and breakdown).
When I changed mine, as preventive maintenance, at 85,000 miles, I found 3 cracks.
A new pulley was only $12 and only takes another minute or so to replace while the belt tension is released (e.g. attaches to the engine with a single bolt).
