821 - 840 of 859 Posts
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
Hi all, I am new to this forum, looking to buy a 08 CLK280,It's Australian delivered, 104,00 km's. If someone could decode the VIN for me it would be much appreciated. Vin is WDB2094542T097626.
Thanks in advance John.
Here's the data card:
If you are looking at it for potential balance shaft issues, as a MY2008, it will be beyond the range.
2005 Mercedes-Benz CLK280
Hi, this is my first message. Recently I acquired a CLK280, year 2005. VIN: WDB2093541F188960 and engine M272 272940 30 267394. I would like to know if the engine is in the range affected by the balance shaft. Thank you very much in advance for the help.
Yes, it is in the range.
i have a 272 v6 motor got 6300km on it went slow in water and broke one conrod
got new engine and fit it but is it better to fix the conrod and sell complete motor or better to strip and and sell parts
2006 CLK 500
Can someone check mine - I didn't know there was a law suit about this
WDBTK75G86T069594 clk500 2006
I'm at 81k miles.
I had some computer transmission thing replaced where I'd be driving then the car would just shift into 3rd gear at random - I had that fixed, no issues since
How do you claim this if there is an issue
2006 CLK 500
I'm at 81k miles.
I did a vin look up and the engine is V8-GASOLINE ENGINE M113 - so it do not believe this is one of them
2008 CLK-350 Convertible
I'm at 81k miles.
Yes, there was a lawsuit, but the window is closed. I think it was for a maximum of 10 years from date of manufacture, I think it was for the original owner only, and I believe the amount they grudgingly paid wasn't enough to do the job anyway.
On the bright side, it was mostly for the 350, only a very few 500s were affected.
What I AM sure about is that Rudeney will correct me where I am wrong - and I appreciate it!
Actually, no "500" car were affected. For the V8, it would be the M273 450 or 550 engines. The M113 500 was not involved.
It's a MY2006 - no need to check the VIN - it's in the range.
Hiya
In love with a clk240 with 50,000km on clock. Advertised as a 2004 but might be 2002 second gen ,??
want to check if it s likely to have BALANCE SHAFT FAILURE PENDING ??
VIN IS WBDWBD2093612F119502
Can anyone possibly advise. Want to buy tomorrow. A bit stressed about it. TIA.
First of all, I have moved this to the correct forums since your car is a W209, not a W209. Second, the M112 2.6l in your CLK240 was not involved in the balance shaft problems. Only the M272/M273 engines are a concern, and only from 2006-2007 (plus the 2005 R171 SLK350).
Hi looking at a 2007 CLK350
Can I please get a VIN Check?
WDBTK56F57F209563
Go to this site and plug in your VIN to get the build sheet and specifically your engine's serial number:
Then refer to this for the affected ranges:
CLK350, W209
Hi, I don't understand how to look up the vin # to see if my engine is a affected by this problem. My vin is WDBTK56676TO69749 . My Milage is about 135000. The engine appears to run fine. No codes on my CLK350 . Should this be a problem and if so, how would I know.
