1998 E300D
My current ride happens to be a 2013 E350 wagon which I adore. I had to let my most beloved W210 1998 E300D go due to age.
But here is my most baffling question as it actually concerns both cars and probably 99% of Mercedes.
Can anyone explain why, when I move the passenger seat towards the rear or the front, the Headrest goes all the way up? For us not-tall folks
this is beyond annoying! Maybe I just haven't learned but I would love to have someone educate me on how to STOP the dang headrest from
going up! Is there a way to stop this bad behavior?
Any ideas??
W212 350CDI -09 W219 320CDI -07 Ex:W220 320CDI -01 Ex:W210 270CDI -01 EX: W211 320CDI -04
Edit: mine goes down when moving front, and up when going rear. Logical, if you need more space for foot you are tall and headrest goes higher. There something wrong if headrest goes only up
Edit2: why its bother you anyway, since you shouldn't need to chance anything when you store settings in memory, or is 3 memory place not enough?
1998 E300D
Well, Sir. Thank you.
My experience with Mercedes has been that moving the passenger seat forward or backwards raised the headrest to full height. It is a built-in mistake.
Unless one is Sitting in the passenger seat one does not use the memory buttons move move the seat forward or backwards or to tilt the seatback.
So when I get in to drive the car, if the last passenger had the seat halfway or farther back, then I have to move the seat forward in order to have the Safest
view out the backseat window. And sometimes I also have to tilt the seat back. And the same goes for when I open the passenger door and want more room in the front to
either load something on the floor or work under the dash etc. I push the horizontal seat button to move the seat back and it raises the headrest so that then I have to sit there and
wait while I move the headrest back down. Stupid!
I was just looking for a setting to STOP this bad German behaviour!!!
And if that fails I will take your suggestion and just program in the setting to memory # 3 (never used in any car I have ever known)!!!!!!!
Like I said it might be something wrong in you seat if it goes always up. I just tested my C219, it does down when moving forward and rises when reversing seat. In the end position of headrest is remained same just depending where seat is.
My W220 otherhand does not move headreast at all, if seat is moved.
So to confirm I must check my W212 how things are there because evidently this feature has been changed.
I never heard that would be disabled, but I can dig my SDS if I find something...
Edit: I believe I found it in C219 settings (CLS is much easier in SDS simulation mode than W212)... "Kopfstützenvoreinstellungen" sound promising... there is also feature for passenfer head rest position if passenger seat not occupied "Nich-Belegt-Stellnung Beifahrerkopfstütze" Those are in developer mode, in normal mode there is one setting called Headrest pre-control, I have no idea what it is.
Edit2: Yes that Headrest-Precontrol is right one. Found it on W212 too and Xentry explains it. It is active by delaut on coutries like USA, JPN, AUS, KOR, SNG, HNK, CHN, persian gulf, not active in rest of the world.
So find an indy who has SDS and they can disable that feature
