1 - 11 of 11 Posts
ok i lost my key on the vito 108d s reg , i went to merc dealer and they say it has a transponder key ,BUT the key that i lost was not as it was the same as my other vito key ie ; very thin and small and they even said that it is not a transponder key ummmmmmm, the man said strange as on the computor it is a transponder key ,well i came home got the barrle off sorted it to turn and it lights up all the lighs ie: ing,heater , brake lights etc, when i turn it over it trys to start all the time then it will start after about 1 min turning over but it runs like it is on 2 cylinders or running out of fuel it did not do this before i lost the key it was a mint runner any ideas plzz ???
V220 CDI 2003
Hi Tuggy, Strange, If it has a immobiliser, it won't start full stop. but you seem to be able to run the engine?! there might be two separate problems here.
Does you van have an assyst computer in it? if it has then it would say 'start error' and refuse to even turn over.
no m8 not that i know of it just a standard 108d van ,the van been stood for about 3 weeks but was great till i lost keys ,like i said it start but like running on 2 cylinders , i topped up the fuel today just to be on safe side but still the same i even tood it lol but still the same , IF it was a transsponder ket do u knoe what would happen if i got the ingnition switch turning with out key / like i took the black cap on the back ??????
V220 CDI 2003
Right, Just to clarify, In my opinion your van does NOT have a Immobiliser hence no transponder key.
The starting problem is a seperate issue and you will have to find what is causing this, do all the usual checks along the fuel lines and fuel rail, not forgetting the Fuel filter ect..
Have a look to see if you can see if there is any air in the fuel pipes, this is usually visible at the fuel filter connected pipes, also if your fuel filter has a 'water drain' ( this type of filter has a hole in the front of it with a small pipe to drain the water in the fuel ) in it then drain this too.
Hope this helps mate
Discussion Starter · #5 ·
sarge on my ingnition switch there is a black cap on the top that just pushes on to the switch it as a black pipe coming from it and inside the black cap its self there is a copper coloured washer anyideas m8 ????
V220 CDI 2003
Sorry mate, can't imagine what that maybe,...however if you took a few pics of it & put it here, then we can have a look at it for you. :thumbsup:
V220 CDI 2003
Tuggy if it is an immobiliser, & you need a key, then why don't you just pop down to you local Mercdads and get a replacement key made up?
I mean we can't be messing about with the security of these vehicles now can we? You can cause damage to other areas of the electrical system by trying to bypass it etc.
Simple, you own the van, take the V5 to the Mercdads and they will sell you a key.
The main reason why anyone would want to bypass the security system would be if the van is stolen, not that I'm suggesting this is the case here.
Hope it helps mate:thumbsup:
Discussion Starter · #9 ·
I Did This M8 Lol And Guess What Up To 6 Weeks For A Key Then And Tranchip Wat Ever That Is Then A Day Laubour And To Top It All No G/tee Its That They Say Lol , Tbh M8 Wish Some One Would Pinch The Bloody Thing At Least They Could Start It L,ol But I See Ya Point M8
Discussion Starter · #10 ·
Oh Bye The Way M8 If Ya Ever Need Parts My M8 Breaks The V-class All The Time He Is The One Who Told Me And Say It Is The Transponder He Will Sort Me One This Week He Said So If Ya Need Anything Let Me Know I Might Be Able To Help Ya
V220 CDI 2003
Mighty nice of ya matey, might take ya up on that offer some time, as I'm sure fellow members will on the forum.
SARGE
1 - 11 of 11 Posts
