i'm kinda a new-b to the mercedes i have an 89 260e with around 1605 miles.. i'm expirencing some bad idle problems where the car is just barely running... if i keep it going it will eventually stall.. when i try to drive the car it will drive fine for about 2 min than it will start slowwing down and not moving.. i've put the gas down to the floor and i get some popping (sounds like its from the engine compartment somewhere?) is anyone else having the same problems..?? thanks
Try to clean you gas tank. You can use some water removal. This could be if the weather is cold at the place you are now. I do not know if it will Helpp but it will coast you only a few dollars. I use it some time in the very cold days.
