83 300D-T
I noticed the first time I backed up at night that I have no back-up lights working. I checked both bulbs and they are fine. Are they wired in series so if one side goes they both go? Or is there a separate fuse just for those lights that may be bad? Where do I start to track down the source of the problem? Steve
84 230CE & 84 300DT
I think you have the right idea. Check your fuses first. Your fuse box is in the engine co...
I think you have the right idea. Check your fuses first. Your fuse box is in the engine compartment on the drivers side of the firewall right next to the hood hinge. The inside cover has a list which fuses protect which circuits.
Then check your connections. Make sure you don't have any short circuits. It can also be a bad back up switch.
Good Luck!
