Mercedes ML-320 1998 + Mercedes C230 1997
My 1998 ML320 back doors doesn't open using inside lever. I remove door panels and actuators and everything seems to be perfect. But something inusual happens, after i replace the door panels the lever works, but when i pull the lock down and up again the lever stops to work. i mean, i cna't lock the back doors cause the levers doesn't work.
Some idea? Thanks
99 White ML320, 13 Audi S5,84 300ZX Turbo, 03 Audi A4, 03 Audi TT, 65 Ford Galaxie Conv
I seem to remember something about child locks. Did you check that?
yes, i look for that but can't see nothing, i think Ml's doesn't have child locks or yes?
I just read an old post about this issue. Now tell me, the button that locks the windows locks too the doors to open from inside?
Window lock does not affect the doors. I will read my manual when I get home tonight unless someone answers before then.
I have the same problem evere since I removed the outer door handles when I got the truck painted. When I put them back on and only after I first lock the doors, the inside handles won't work. I never bothered to diagnose the issue, but I think that it may be the alignment of the outside door handles when I put them back on. Hope this helps.
