Does anyone have access to a pdf of the page(s) of the WIS related to changing B200 front engine mounts? I have new ones to install and I'll do it myself if it's not too much of a pain.
Thanks in advance.
Thanks in advance.
Can you send me in a pm full VIN, im not sure how the VIN goes for petrol W2452071JXXX ?Thank you! My car's VIN ends in 301566, 5 speed manual, B 200 naturally aspirated.
WDDFH33X78J301566
Thanks!
I will upload you the files when i get back roughly 2 days if ur not in hurry.May i have the manual about WDD2452342J197253
Other files are the same like on B200 petrol. It's all the same.
Hi guys my B200 Turbo is a bit different..could you dig out the info on it? VIN WDD2452342J270462.I will upload you the files tonight if your aren't in hurry
EDIT: I hope this can help you out, if not. Send me your VIN and we will pull out exact files and instruction that u wish for/need
This is for 245207, i dont know how the VIN number goes for B200 petrol
I can't find the paperwork but because my car's a manual, you should check with the dealer locally.Hi, anyone come up with Mercedes part numbers for these mounts?
Stealer won't give me part numbers...I got 3 sussed only the (right rear?) 110 on that diagram I can't identify the Mercedes part number A169240.... for and there seems to be a couple of different ones!I can't find the paperwork but because my car's a manual, you should check with the dealer locally.
