1 - 8 of 8 Posts
I have 2 malfunctions, right lamp, right back up lamp on. All the bulbs are new genuine mercedes and the panel holding the bulbs have been replaced. The 2 malfunctions will only come on when the headlights are turned on. The lights work correctly at all times.
The SDS tells me it is the Front SAM (n10/1) or light switch module (S1). Has any one had this problem before?
I have another W203 that I could swap parts to help diagnose, if one of these parts are swapped from one W203 to another is there any programming that needs to be done?
If you swap a SAM, it does need to be recoded if the vehicles have different options. However, your problem is more likely a bad wiring harness than the SAM.
I'd trace the harness. You say you replaced the bulbs and the panel? Check around that area to make sure you didn't damage the harness when replacing that.
Remember, the system senses resistance (or a lack thereof) to detect a bad bulb. All you have to do is check the resistance of the wires, comparing the left side to the right side, and you can determine if it is a harness problem.
I ruled out light switch module (S1). So I'm down to the Front sam.
In regards to an issue with the wire harness I cant imagine that being the problem or I would have these codes coming up when the light switch is in the off position. I only have these codes when the night lights are activated.
I'm going to hook up the SDS and see what other options I have with the front sam, maybe I'll try to reprogram or some thing.
1 - 8 of 8 Posts
