Benzless for now...
What would happen If I removed the aux pump from my system? I'm mostly only curious, but I ask becuase it would facilitate an easier installation of the circulation tank heater I bought. Does that pump stay on constantly when the car is running or just turn on as needed?
1984 300D (235,000 miles), 2001 E430 (78,100 miles)
I assume you're talking about the small electric pump in the heater line, located roughly behind the alternator.
While I don't know what turns it on, it's purpose is to provide increased coolant flow to the heater at idle for better cabin heating.
If I understand correctly, if it locks up or in some other manner malfunctions, it can do unfortunate things to the ACC unit.
I didn't feel that I was deriving any particular benifit from the aux pump, so I had no problem w/ removing it. I got a 90 degree elbow hose of the appropriate size, and found that the pipe going to the firewall is a smaller size than the one going to the water pump, however, it was close enough such that I was able to persuade the hose over the larger pipe.
Personally, I've not missed having the aux pump, and the cabin heat I'm getting seems perfectly adequate.
Benzless for now...
Thanks for the information, I think I'll take it out and install my heater tank in it's place.
