1 - 1 of 1 Posts
Has anyone changed the the auxillary belt on an OM602 engine? the tensioner roller seems to be out of line to all the other pulleys and i want to take it off to see if the bearings are ok. I have tried to take off the tension by slackening off the main pivot nut at the top and used a bar to try and take off the tension on the spring but it does not seem to work. do i need to disconnect the damper?
any help would be appreciated!
1 - 1 of 1 Posts
