98 E320
My aux fans are not turning on and since it is starting to warm up in South Florida, I probably need to get this fixed soon.
I can not seem to get the car in the fan test mode and I am wondering what I am doing wrong. I am
1) Turning the key to position 2 (running position)
2) Holding both Auto buttons for >10 seconds
3) Holding the REST button for 5 seconds.
When I scroll to 20 the value is never 10 and is usually either 3.2 or 21.3, which is nowhere near the 10 it should be.
I have already change the motor for the aux fan, since when I connected 12V to it it didn't work.
Thanks in advance for your help.
98 E320
Discussion Starter #2
Ok.
I finally got the car into the fan test mode and I hear and see the fans running. But the value for the index of 20 is still 21.3 and not 10.
Does anyone know what this means?
SLK320, MKV Jetta TDI, Mini Cooper S, Lincoln Mark LT
Hold the REST button for 5 sec. Use AUTO to scroll.
10. Blower Control Voltage: 6.0V
11. Emission Sensor: 2.4V
12. Sun Sensor: 4.1V
20. Control Current for Auxiliary Fan: 3.2mA
21. Engine Speed: 44 or 4,400rpm
22. Vehicle Speed: 0 (Car must be moving to show a reading)
23. Terminal 58d: 32 or 32%
24. Battery Voltage: 13.3V
Go to:
MERCEDES-BENZ: A/C Diagnostics & Evaporator Replacement
98 E320
I have read in other posts that the value for #20, referring to the Control Current to the Aux fans has a maximum value of 10 mA.
The value I am receiving is double the value at 21.3 mA.
Could the ECT be causing this? Where is the ECT located? Since I have read that if I unplug it, the fans should run constantly.
Thanks.
This isn't like the old cars, where the auxiliary fan used a simple switch. The ECT signal comes from the instrument panel.
I don't know why you are seeing >10 on that reading. Perhaps your pushbutton unit is bad.
